Ansys Learning Forum Forums Discuss Simulation Fluids Import parameters from workbench to fluent Reply To: Import parameters from workbench to fluent
Min Zhang
Do you perform Optimization? If not, you can define your parameters using Text User Interface, i.e. “defineparameterinput-parameteradvanceduser-in……”
These parameter (F1,F2...) are listed in the "Parameter Set" in Workbench,their value can be adjusted manually .
