Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Mesh is not always symmetric. › Reply To: Mesh is not always symmetric.
peteroznewman
Hi Jimmy,
Geometry that is sweepable makes good quality meshes. If you use DesignModeler, you can Slice the solid using Planes to make sweepable bodies. If one face has 4 sides, a Face Meshing mesh control can make a good mesh.
Export a Parasolid file of your geometry from DesignModeler or SpaceClaim and attach that to the discussion. I can download that file and show you what can be done.
Let me know if you are using 18.2 or 17.2 and if you are using DesignModeler or SpaceClaim for your geometry editing.
Regards, Peter
