Ansys Learning Forum Forums Discuss Simulation Fluids Tips for my project of wave generation against current. Reply To: Tips for my project of wave generation against current.
Raef.Kobeissi
This is an advanced simulation and it comprises the following elements:
- Open Channel  - You need to use the VOF model ( volume of fluid)
-6DOF Dynamic mesh method - You need to use the 6DOF dynamic mesh method to simulate the object bobbing up and down
It is a transient simulation and it is perfectly achievable in ANSYS Fluent. You need to get all the properties for the 3D object ( Mass, Mass moment of inertia etc..) you need to represent the solid body as a cavity and you will have 2 fluid materials (Air and Water).
An example of this simulation in 2D:
https://www.youtube.com/watch?v=OiO9X9fes2I
Something similar in 3D:
https://www.youtube.com/watch?v=40UR7pFfJGA
