Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DYNAMIC MESH SIX DOF › Reply To: DYNAMIC MESH SIX DOF
ADITYA
Sir, Sorry to disturb you again. Actually I am working on Darrieus type vertical axis wind turbine with three blades of NACA 0018 profile. After following the procedure you have adapted in your tutorial  titled "  CFD ANSYS Tutorial - Simulating Turbines using dynamic mesh and 6DOf | Fluent" the turbine is not at all rotating. Here i have two different zones one for stator and other for rotor, the rotor is equipped with three blades of the turbine at 120 degree angles apart. Sir where is the problem. Wating for your reply.
Aditya
