Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › shell element with orthotropic materials gives very different results from experimental data › Reply To: shell element with orthotropic materials gives very different results from experimental data
November 14, 2017 at 4:30 pm
peteroznewman
You're welcome Emir!
Here is the shell mesh Element Coordinate System override method.
Create a new Coordinate System using Manual with ID = 12.
Then add a Command Snippet to the Modal branch like this.
Here is the text of that command:
/PREP7
EMODIF,ALL,ESYS,12
FINISH
/SOLU
It worked for me!
Best regards, Peter
