Ansys Learning Forum Forums Discuss Simulation Fluids Fluid flows upwards despite the fact that gravity is enabled Reply To: Fluid flows upwards despite the fact that gravity is enabled
Raef.Kobeissi
You can use inlet pressure instead of velocity inlet, this way you can set the pressure at whatever value you want but you wont be able to control the velocity.
