Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluid flows upwards despite the fact that gravity is enabled › Reply To: Fluid flows upwards despite the fact that gravity is enabled
Raef.Kobeissi
Hello, from the contours you just showed it looks like you have high differential pressure and I believe the flow behaviour upward despite gravity is perfectly normal due to high pressure and flow deflection.
Regards
