Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluid flows upwards despite the fact that gravity is enabled › Reply To: Fluid flows upwards despite the fact that gravity is enabled
Raef.Kobeissi
It depends on your geometry, when you rectified your gravity acceleration have you restarted the simulation? Can you share the pressure and velocity contour in your simulation please.
Cheers
