Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › shell element with orthotropic materials gives very different results from experimental data › Reply To: shell element with orthotropic materials gives very different results from experimental data
emirdegirmenli
Thank you, Peter, I've attached some images. Actually, I only drew one surface and one solid on SpaceClaim later click "generate mesh" in Mechanical and adjust the only size. I don't know differences between solid and solid-shell elements. Can you give me some advice I can research this issue, best.
material
mesh
results
