Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › shell element with orthotropic materials gives very different results from experimental data › Reply To: shell element with orthotropic materials gives very different results from experimental data
peteroznewman
Please post an image of the material properties for wood (or an xml file exported from the database) and an image of the mesh.
How many solid elements are you using through the thickness?
Are you using solid-shell elements or just solid elements?
