Ansys Learning Forum Forums Discuss Simulation Fluids Compare the eddy dissipation model rate with the chemical reaction rate Reply To: Compare the eddy dissipation model rate with the chemical reaction rate
Vishal Ganore
For any reacting flow model, the overall rate is available in CEL and post-processing as ..Molar Reaction Rate. To output, in addition, the separate ..Eddy Dissipation Reaction Rate (i.e. the rate from the EDM) and the ..Chemical Reaction Rate (i.e. finite chemistry rate) you need to add the CCL to the Solver arguments: -ccl shortrules.ccl, where shortrules.ccl contains: LIBRARY: VARIABLE: edmrate Option = Definition Output to Postprocessor = Yes END VARIABLE: kinrate Option = Definition Output to Postprocessor = Yes END END
