Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › R18.0 ANSYS Student installed on Surface Pro 4. Edit bars moved among each other. › Reply To: R18.0 ANSYS Student installed on Surface Pro 4. Edit bars moved among each other.
November 8, 2017 at 12:09 am
pgl
Don't launch the product, instead go to the ANSYS Workbench shortcut on your desktop (or start menu) and right click to select Properties. Under Compatibility select "Disable display scaling on high DPI settings". Â
