Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Additional meshing around the crucial element › Reply To: Additional meshing around the crucial element
November 7, 2017 at 6:17 pm
Hi Mom,
I can't quite see the surface you are trying to inflate from the attached file, which I have included below.
A shaded rendering of the geometry might be easier to see. Is this a Mechanical or a CFD mesh?
I slice geometry in DesignModeler to get sweepable bodies that can easily be inflated such as this example of an airfoil.
Can you attach the geometry in Parsolid or other neutral file?
Cheers,
Peter
