Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › parametric equation driven a curve › Reply To: parametric equation driven a curve
cos2pi
Thank you for your reply,
Can i use the same method, if i want to create ít as a 2D sketch and then extrude?
The thing i wish to draw is a wavy channel coldplate.  Where the wavy pattern is a sinusoidal function with variable amplitude and frequency.
 So i need a thickness on the fin, and a height
