Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Creating only surface mesh on midsurface › Reply To: Creating only surface mesh on midsurface
peteroznewman
Is this what you want?
It came from a midsurface body in my CAD system that looked like this:
That came from a solid cylinder that looked like this:
These are all 3D objects. I think you are using the term 2D when you mean a surface body that is covered with a shell mesh.
ANSYS reserves the term 2D analysis for "flat" geometry that only exists in the X-Y plane of the CAD system. Don't set the Geometry type to 2D if what you want to import is a 3D object.
Hope that helps.
