Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How can we measure the visocity of fluid › Reply To: How can we measure the visocity of fluid
Raef.Kobeissi
You usually define the viscosity of a fluid before you run the simulation, unless you define it as a finction of temperature (polynomial function for example). If you do that then you can easily get the temperature data and create a function to calculate the viscosity in Fluent or CFD Post.
I invite my other colleagues to share any other ideas!
Cheers
