Ahmed
Update:
I restarted my Laptop and opened Ansys Fluent. it worked properly this time. I performed 1000 iterations in 27 seconds. Later, I restarted my laptop and opened Ansys Fluent again and it went back to performing slowly. However this time I copied the messages that appeared in the console tab in both slow and fast cases. All the messages were same except the following.
Slow Case:
Multicore SMT processors detected. Processor affinity set!
Fast Case:
DESKTOP-621A36I is already loaded (23.9042%). Process affinity not being set.
I hope this helps you with your diagnosis.
Thank you
