Ansys Learning Forum Forums Discuss Simulation Fluids termination problem when using CFX User Fortran Reply To: termination problem when using CFX User Fortran
Min Zhang
This problem may be caused by an issue that CFX 16.2 is not compatible well with Intel Fortran Composer XE2011. I just installed the Ansys 15.0, then started the same run and stopped it, everything became normal.
