Raef.Kobeissi
Hello 300 iteration within 7 seconds under the specs you mentioned sounds impossible to me even if the model was 2D. Could you please provide a description of the model you were running.
I believe if the number of elelments is high in your model, an hour would make sense for 300 iterations on a PC similar to what you’ve described.
Cheers
