Ansys Learning Forum Forums Installation and Licensing Ansys Products Licensing Problems with Ansys 18.2 Reply To: Licensing Problems with Ansys 18.2
peteroznewman
You need to uninstall ANSYS and clean out two directories before you install ANSYS again.
In Windows Explorer, type %AppData% in the path field. You will be in the Roaming directory. Delete the Ansys folder, then go up a level and down to the Local directory and delete that Ansys folder too.
