Ansys Learning Forum Forums Installation and Licensing Ansys Products R18.0 ANSYS Student installed on Surface Pro 4. Edit bars moved among each other. Reply To: R18.0 ANSYS Student installed on Surface Pro 4. Edit bars moved among each other.
Adil
Hello PGL, thanks for the Information. I changed only Resolution 1920 x 1080 it is enough?
Where can i find Compatibility select "Disable display scaling on high DPI Settings. Thank you.
