Ansys Learning Forum Forums Installation and Licensing Ansys Products Numerical Problem Size limits with a model that should run Reply To: Numerical Problem Size limits with a model that should run
jonnyflowers
The issue definitely has nothing to do with anything exceeding limits at the moment, I may have exceeded this during an initial run, so what Sergey said seems likely, it could be as simple as a variable not being reset in the setup cell.
