Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › BFINT command for interpolating temperatures › Reply To: BFINT command for interpolating temperatures
Arun Kumar
No. BFINT is a /POST1 command, so the model must be solved and a .rst file must be available. An alternative method to interpolate data between models is using the mapping option of the MOPER command. Mapping is done using four arrays and the "MOPER,parR,par1,MAP" option. The required arrays are: 1.three-column array that stores the coordinates of the input data. 2.array that stores the data (e.g., temperature) that corresponds to the coordinates stored in the first array. 3.three-column array that stores the designation coordinates for the interpolated data. 4.array where the "*MOPER, parR, par1, MAP" command writes the interpolated data. More details on *MOPER command can be found in MAPDL Command Reference Manual (help/anscmd/HlpC_MOPER.html).
