Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Changing tolerance for Boolean operations? › Reply To: Changing tolerance for Boolean operations?
Arun Kumar
Check the default value of tolerance for boolean operations through BTOL, STAT command. Provide a tolerance value about 1/20th to 1/10th of the minimum KPT distance using the BTOL, tolerance value
