Ansys Learning Forum Forums Discuss Simulation General Mechanical Mechanical database automatically saved when Mechanical is closed Reply To: Mechanical database automatically saved when Mechanical is closed
Arun Kumar
When a Mechanical session is closed, the database is automatically saved to ensure that if it is reopened in the same Workbench session the latest state is restored. For example, if you rename a Mechanical object from A to B; and then close and reopen Mechanical in the same WB session (without saving the project), the object name will be B.
