Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Numerical Problem Size limits with a model that should run › Reply To: Numerical Problem Size limits with a model that should run
I have few requests from students facing the similar "numerical limit" issue. The most simple way to reproduce the problem is to exceed the specified limit (32k) at least once, and in the following runs the numerical limit error will pop up with no respect to the actual size of the model. Duplicating the project or clearing generated data or closing the workbench or restarting the pc do not solve the problem. However, if you duplicate the Model cell and make a new Setup cell, it works fine. So the issue seems to be seat somewhere in the Setup cell of the project. Still have no idea how to avoid the error without redefining loads and supports. I also have requests regarding the error about geometry size limits in DM. However, I found no info regarding the limits existing for student version of DM.
