Ansys Learning Forum Forums Discuss Simulation General Mechanical PGVECTORS are not available under the user defined results for linked analysis systems Reply To: PGVECTORS are not available under the user defined results for linked analysis systems
Arun Kumar
To get this result item, insert OUTRES,ALL,ALL command through command object.
