Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Increase the maximum number of equilibrium iterations per solution step in Mechanical › Reply To: Increase the maximum number of equilibrium iterations per solution step in Mechanical
cbhavsar
The maximum number of equilibrium iterations per each solution point is 25 based on the default setting of the NEQIT command. To change the maximum number of equilibrium iterations, you can issue the NEQIT command from within a Command Object. For example, issuing NEQIT,30 will increase the maximum number of equilibrium iterations to 30.
