Ansys Learning Forum Forums Discuss Simulation General Mechanical Plot the full body when a symmetry region is defined Reply To: Plot the full body when a symmetry region is defined
Arun Kumar
if a symmetry is defined with Zaxis as normal, you can activate Graphical expansion (Beta) into the symmetry folder (not the symmetry region) and request a Cartesian, Half expansion with a tiny negative Delta Z. That will not work with Delta Z = 0
