Ansys Learning Forum Forums Discuss Simulation General Mechanical Hexahedral elements compare to 10 node tetrahedral elements for contact problems Reply To: Hexahedral elements compare to 10 node tetrahedral elements for contact problems
cbhavsar
With hyperelastic materials, lower order hex elements are optimal, in terms of robustness and accuracy, but not always practical. It can be helpful to drop midside nodes and let the code invoke enhanced strain technology when bending is excessive. Higher order elements can be more susceptible to turning inside out under excessive bending.
