Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error: Radiation element has negative or zero temperature › Reply To: Error: Radiation element has negative or zero temperature
October 17, 2017 at 9:51 am
Define the substeps for proper radiation calculation otherwise you may get negative values. Also, specify an initial temperature for the model around the expected temperature so the solution starts farther from zero. Make sure an offset temperature has been defined (TOFFST).
