Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Define spatially dependent loads across multiple load steps in ANSYS Mechanical › Reply To: Define spatially dependent loads across multiple load steps in ANSYS Mechanical
cbhavsar
Step1: Define a spatially dependent load for load step 1. For example, a pressure defined by tabular, with “independent variable” set as X. Step2: In “Details of the load”, change “Graph Controls” to “Time”, and scale the magnitude of the load along time.
