Ansys Learning Forum Forums Discuss Simulation 3D Design Export only the face of a solid in CAD format Reply To: Export only the face of a solid in CAD format
Arun Kumar
This is not directly possible, but user can create a surface from the face using Concept//Surfaces from Faces. And then suppress the solid and finally export the geometry. You should be able to delete the created surface and unsupress original solid.
