Ansys Learning Forum Forums Discuss Simulation General Mechanical Is only defining the node/element id sufficient for use with external data? Reply To: Is only defining the node/element id sufficient for use with external data?
Arun
No. The X, Y and Z coordinates of nodes is also required. This information is contained in the .CDB file.
