Ansys Learning Forum Forums Discuss Simulation General Mechanical How can you use surface elements to get the surface strain data? Reply To: How can you use surface elements to get the surface strain data?
cbhavsar
The procedure is as follows: - Generate the 3D solid Mesh - Using esurf command, create surface 281 elements on 3D solid elements - solve your model - Calculate surface stresses/ strains as required in output
