Ansys Learning Forum Forums Discuss Simulation Fluids Wrap around target option in the Project tool Reply To: Wrap around target option in the Project tool
cbhavsar
The Wrap around target tool allows you to take planar curves or text and wrap them onto planes, cylinders, and cones. You may choose a surface target or establish a direction for the wrap. Curves can be wrapped onto geometry with per-existing imprinted wrapped curves. Surfaces may be used for wrapping, however only the surface edges are used to wrap around the target. To wrap a curve, text, or a surface around a target object: §Click the Project tool §Check ON the Wrap around target option §Click the curve, text or surface you want to wrap §Click the Select Direction tool guide and choose a direction, you will see purple lines on the target as a preview §Click the Complete tool guide or press the Enter key
