Ansys Learning Forum Forums Discuss Simulation Fluids Compile and load a UDF when running Fluent via a journal file Reply To: Compile and load a UDF when running Fluent via a journal file
Arun Kumar
There are two commands needed. The first to compile the UDF: /define/user-defined/compiled-functions compile libudf yes sourcename.c "" And the second to load the library that was compiled in the previous step: /define/user-defined/compiled-funcitons load libudf Note that 'sourcename.c' is the name of your UDF file and the "" are two quotation marks in sequence (needed to terminate the string array input to Fluent).
