Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Check the unsteady (transient) sampling times? › Reply To: Check the unsteady (transient) sampling times?
October 17, 2017 at 6:41 am
admin
For transient calculation data, for which a time averaging process was carried out, Fluent samples time from the instant time averaging is turned on and uses it for averaging. if you want to check the sampled time used, enter the following TUI command which returns the time used for time averaging: (rpgetvar 'delta-time-sampled).
