Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Set up a wall that is permeable to fluid and not to particle › Reply To: Set up a wall that is permeable to fluid and not to particle
admin
Set a porous-jump with the following properties: Face permeability = 10e10 m² Porous Medium Thickness = 0 Pressure-Jump coefficient = 0 Still in the Porous Jump panel, set the Discrete Phase BC Type to reflect
