Ansys Learning Forum Forums Discuss Simulation Preprocessing Generate automatic metric report from ANSYS Meshing Reply To: Generate automatic metric report from ANSYS Meshing
admin
1) Copy/paste the code below into a file with the suffix "*.js" 2) Run the Jscript file in ANSYS Meshing via "Tools -> Run Macro" //+++++++++ JScript code ++++++++// var DS = WB.AppletList.Applet( "DSApplet" ).App; var Nodes=DS.Tree.GetObjectByName("Mesh"); // Choose the metric to evaluate Nodes.MeshMetric=7; // 1=Element Quality, ..., 7=Skewness DS.Script.doMeshMetrics(); // Access properties var nelements = Nodes.Elements; // number of elements var nnodes = Nodes.Nodes; // number of nodes var min = Nodes.MeshMetricMin; // minimum value depending on the choice of the mesh metrics var max = Nodes.MeshMetricMax; // maximum value depending on the choice of the mesh metrics var avg = Nodes.MeshMetricAverage; // average value depending on the choice of the mesh metrics /// write to file var fso = new ActiveXObject("Scripting.FileSystemObject"); var a = fso.CreateTextFile("c:testfile.txt", true); a.WriteLine("Mesh Metrics"); var str1 = "Number of Elements = " + String(nelements); a.WriteLine(str1); var str2 = "Number of Nodes = " + String(nnodes); a.WriteLine(str2); var str3 = "Minimum Metric Value = " + String(min); a.WriteLine(str3); var str4 = "Maximum Metric Value = " + String(max); a.WriteLine(str4); a.Close(); //+++++++++ END ++++++++//
