Ansys Learning Forum Forums Discuss Simulation 3D Design Why can’t the body be moved in SpaceClaim? Reply To: Why can’t the body be moved in SpaceClaim?
pgl
Please check if you have applied any Assembly constraints under Design Tab on your Components in ANSYS SpaceClaim. If there are any Assembly Constraints like Align, Rigid,Tangent, etc, it may restrict the movement of the parts depending on the applied constraint. To move the Component using Move command, you will have to remove the Assembly constraint accordingly.
