Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Is there an easy way to select multiple faces on a model in SCDM? › Reply To: Is there an easy way to select multiple faces on a model in SCDM?
September 29, 2017 at 11:33 pm
pgl
Yes. You can select one or more objects quickly and easily by using the Select tool. Click the first face of your design, hold down the Ctrl key, and then click each individual selection you want to add to or remove from your original selection. For more information, refer to the SpaceClaim Online Help.
