pgl
Unfortunately we do not support UHD and 4K resolution displays.  A workaround that others report as working fine is to reduce the resolution (try 1920 x 1080) and then also adjust your windows scaling settings. Reboot after making the resolution changes. Also try on the ANSYS Workbench shortcut and select Properties. Under Compatibility select "Disable display scaling on high DPI settings".  Here's what my Properties dialog box looks like:
