Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CFD-post application failing to connect › Reply To: CFD-post application failing to connect
vganore
Take another result component in workbench from component system and connect your solution cell with new results component. See if that helps.
If same problem persists then try opening CFX in a standalone mode through windows start menu. See if it gives same error. Might be a license issue.
