Ansys Learning Forum Forums Discuss Simulation Fluids Creating an internal inlet within a geometry or using outlet velocity turbulence profile for inlet Reply To: Creating an internal inlet within a geometry or using outlet velocity turbulence profile for inlet
Holger Grotjans
Well, sure you can easily create a source term in CFX. Just look at the documentation. For your application you can specify a domain source term specified by a CEL-function, making use of the step-function, to limit the source term to a specific region in the domain.
See section 17.4.1.2.2 in the CFX-Pre Users Guide.
