Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Creating an internal inlet within a geometry or using outlet velocity turbulence profile for inlet › Reply To: Creating an internal inlet within a geometry or using outlet velocity turbulence profile for inlet
I attached a few images of the geometry, additional variable concentration, and velocity field to get a feel for the project.Â
 entire geometry with inlet on upper left and outlet at bottom right
 geometry showing inlet and roughness blocks to create realistic turbulence
 Additional Variable in XY plane along centerline
 velocity field: you can see turbulence takes time to develop, so inserting the additional variable in the middle of the plume would create the most realistic model. I'm increasing the size of the domain to prevent the additional variable hitting the roof as well.
Thanks a lot for your help!
