Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › How to work with STL file? › Reply To: How to work with STL file?
pgl
The best way to work with STL files is to import the STL file into ANSYS Spaceclaim and then convert into a CAD geometry file such a Parasolid. The CAD geometry can then be used by ANSYS Mechanical and other ANSYS simulation products.
Note that generally *.STL files are not able to capture geometry appropriately and ANSYS Spaceclaim helps to repair the .STL file if needed.
