Ansys Learning Forum Forums Discuss Simulation Electronics Current used in calculations as Current Density Reply To: Current used in calculations as Current Density
pgl
I could be way off here, but in the final screenshot you can see the four cylindrical via volumes selected. The calculated current density is showing the min & max for the currently selected volumes. What happens if you change the location to the 4 areas of interest instead?
