Ansys Learning Forum Forums Discuss Simulation Fluids How to monitor the wall heat flux at a moving CHT interface? Reply To: How to monitor the wall heat flux at a moving CHT interface?
vganore
On a moving interface the wall heat flux values do include the complete enthalpy flux across the interface. They also contain the pressure work (Pressure*Area*Velocity) at the moving fluid/solid interface. The correct wall heat flux is available at the solid side of the interface. Monitoring ‘areaInt(Wall Heat Flux )@Domain Interface 1 Side 2’ contains the right value.
