Ansys Learning Forum Forums Discuss Simulation Fluids Display of vector or contour and the mesh lines together via TUI command? Reply To: Display of vector or contour and the mesh lines together via TUI command?
vganore
In Fluent, the TUI command required to display the grid along with the vector and contour display is: /display set render-mesh yes Example: Command to display wall1 and wall2 along with velocity contour at z = 1 /display set-window 1; open Window1 /display set mesh-surfaces wall1 wall2 (); display mesh outline of wall1 and wall2 /display set contours surfaces z=1 (); select the surface where you want to display the contour(z = 1) /display set render-mesh yes; display mesh /display contour velocity-magnitude 0 1; display the velocity contours (range 0-1) on the surface (z = 1)
